my damn starter keeps turning!!!!!!!!
Okay I went to the locl audio shop that I got the solenoid from, and they said it is a grounded base, so I bought another one. Alos a new starter, cleaned the terminal on the battery, and all the conections. I wired it correctly, double checked it, then tried to fire it up. Nothing. Checked the battery and it's good. Still nothing. WTF!! This piece of **** won't start.
BTW I pulled the dash and checked the wiring harness. It checks out okay, but I did notice a black wire that was broken, and I cannot find were it went to. It comes from the headlight switch, and it's black so I assume it is a ground wire. So I put the key in the ignition, and tunrned it on, but did not crank it. While it was on, I grounded the wire and it sparked! WTF!! I don't think a loose wire from the headlight switch can affect the starter can it? I need help. I may just get a new wiring harness if I can figure this **** out.
