Epoxy Garage floor coatings for new garage???
Yes, I did it. I vote - DO IT. Use the 2 part epoxy paint. I used the grey two part paint they sell at Lowes - probably the same thing. When I built the new garage, I did this and have not regretted it. If the floor is smooth, (I made mine REALLY smooth) etch it with pool acid, I think I used 50/50 acid/water. This will clean it too, which is very important. Rinse it THROUGHLY and dry completely - days maybe. Use a REALLY GOOD car paint type mask on your face for the whole process. When the floor is good and dry, roll on the epoxy. I used two units (gallons more or less) to cover 20x24. Be sure to let it cure fully before doing anything on it. I think I let mine set 36 hours. Maybe 48. Give away your creeper - you'll not need it. You'll be able to glide all over the floor in a T shirt.
It resists every chemical, even Berrymans.
Wet tires will not pull it up - actually nothing will pull it up if the prep is right. If you don't like it, you'll have to sand blast it off.
It's slick stuff if you spill water, trans fluid, etc. - watch out.
Two part car paint WILL stick to it and not come off - even with Berrymans.
Get a garage mop - you'll be treating it like a kitchen. At least until it gets covered with parts stuff like mine.
Do NOT use deck paint or regular garage floor paint. Use that crap on your work bench, not the floor. It WILL peal off a floor, even with prep.
