02-21-2003, 05:16 PM   #1 (permalink)
89gt50
driveshaft length T5
going from a c4 to a t5 do I need to shorten or get a new driveshaft?
89gt50 is offline   Reply With Quote
02-22-2003, 01:30 AM   #2 (permalink)
SCOTT
Well, I'm guessing that this is on a 89stang???? You can just use a stock lenght driveshaft since the T5 was used from the factory...I guess the question is-is your current driveshaft a factory one? If not, a junkyard would be cheaper than cutting and rebalancing.
SCOTT is offline   Reply With Quote
02-22-2003, 02:07 AM   #3 (permalink)
knifeman85
i'm going from the '67 c4 tranny and stock driveshaft, will i need to shorten mine? if so how much?(also a t5 conversion)
knifeman85 is offline   Reply With Quote
02-22-2003, 01:04 PM   #4 (permalink)
mgray
I have a '67 coupe that I switched from a C4 to a T-5. I also swapped out the 8" for a Granada 9" and the stock Mustang shaft was too short. I had the Granada shaft shortened a bit instead.
Call the guys out at Mustangs Plus in California as they routinely make aluminum shafts for all combos. They can probably tell you what you need.
Good luck.
mgray is offline   Reply With Quote
