02-21-2003, 07:27 PM   #1 (permalink)
dragman64
Upper A arm pivot
Ok. One of the very large nuts on the upper a arm has backed off. its the one that is the pivot point for the a arm (with the threaded shaft inside). Anyone else have this problem? Should I just locktight it and tighten it back up? Im tearing into it right now, so i'll let you know any more information.
And this is on my '64 Comet.
dragman64 is offline   Reply With Quote
02-21-2003, 07:41 PM   #2 (permalink)
Tonkatech
Upper A arm pivot
This is taken from the FAQs on MustangSteves Board. Reccomends Tack-welding everyother flat... read below for details and visit
http://members.boardhost.com/MustangSteve/
Upper A-Frame Bushing Rebuild
When you remove the 3/4" nuts from inside the engine compartment, retrieve the alignment bushings from each of the 4 bolts (under the fender). Keep track of which ones went where and then put them back in their original locations when you reassemble. Tighten the 3/4" nuts very tight and they won't come loose. The real challenge is getting the new bushings screwed into place with the shaft centered exactly between the bushings and also not putting the bushings in a real tight bind by torqueing the large threaded bushing into the a-frame until it feels tight. The bushings will likely NOT tighten up in the a-frame without bending the sides of the a-frame towards each other. I tighten them until they are all the way in, but not necessarily tight. Then tack-weld every other flat on the hex of the bushing to the a-frame to keep them from backing out. IF YOU DON’T DO THAT, THE BUSHINGS WILL EITHER WEAR VERY RAPIDLY OR THE BUSHINGS WILL UNSCREW FROM THE ARM. (That is not a good thing). Before putting the bushings onto the shaft, take a die grinder with a 1/16" wide cutoff wheel and cut a groove from the end of the shaft, across the threads, cutting slightly deeper than the root diameter of the threads, then into the o-ring sealing area. Do this only on the BOTTOM of the shaft. If you check the physics of it all, that side is never loaded, so it won't cause any additional wear. Deburr the slotted area. That slot achieves two things. 1. It allows the grease to have a path so it can reach EVERY thread on the shaft. Without it, the grease you pump in with your grease gun only gets to the first couple of threads, leaving the rest to give a SQUUEEEEKKK every time you hit the speed bump pulling into the local cruise night. and 2: It gives the grease a pathway to leak (slightly) past the o-ring so it doesn't hydraulically blow out the o-ring when you set the car back on the ground as the threaded bushing turns on the shaft, decreasing the volume of the area where the incompressible grease resides. Nothing worse than watching your brand new o-ring come oozing out from inside the bushing when you lower the car. Before you let the car down, shoot the bushings full of grease, then remove all 4 zerk fittings. Let the car down slooowwwly and then bounce the front end up and down as much as you can. Now, reinstall the zerks and your bushings are properly greased with plenty of, but not too much, grease.
Tonkatech is offline   Reply With Quote
02-21-2003, 07:49 PM   #3 (permalink)
dragman64
Upper A arm pivot
YESSSS! That it! thanks.
02-21-2003, 08:20 PM   #4 (permalink)
Tonkatech
Upper A arm pivot
Glad it is of some help.[img]/phpBB/images/smiles/icon_biggrin.gif[/img]
02-21-2003, 11:16 PM   #5 (permalink)
dragman64
Upper A arm pivot
Anyone got a sorce for the o-rings? I have one more place to try tomorrow. So far no luck [img]/phpBB/images/smiles/icon_cry.gif[/img]
02-23-2003, 10:59 PM   #6 (permalink)
Tonkatech
Upper A arm pivot
My sears hardware has a huge bin shelves with all sorts of pieces, spacers , berings, koter pins, and yes O-rings.
Try Pepboys where they keep Grade 8 bolts and other things.
Also McMaster-Carr at http://www.mcmaster.com/
do a search for O-ring... But I am sure you can find them locally.
