For those that have done this instalation, do you reuse the shaft from the steering box for the long shaft instalation? I cannot figure it out from the article. also if you do reuse the shaft, how do you get it out of the steering box. Thanks
No, you need the TCP steering column kit, for the long shaft. This kit comes with a new shorter shaft, end column bearing and u-joint short shaft to the rack.
