AOD tranny tip.
Also, these OD transmissions should only use Mercon V type fluid. The earlier AODs did not come with it, but Ford service will tell you it is a big improvement for the OD trans. It should NOT be used on in the non OD transmissions, since they use different type seals, and will leak with Mercon V after some time.
------- Work in progress -------
392 stroker crate engine
AFR 185 heads
Lentech Street Terminator + AOD
3,500 rpm converter
3.73 gears
17x9 Cobra Rs, with 255/45/17 BFG KWDS tires
<font size=-1>[ This Message was edited by: 392bird on 3/19/03 8:11am ]</font>
<font size=-1>[ This Message was edited by: 392bird on 3/19/03 8:17am ]</font>
