04-10-2003, 06:13 PM   #1 (permalink)
knifeman85
T5...plugs
okay, i acquired a T5 from my local mustang shoppe and i was wondering about the plugs and switches on it. there is the one in the side of the case which i believe is the back up switch, but there is also one on the top in front. i have no clue what that one would be, does anybody know?
i know it's been asked before, but how much fluid can t5's hold, and what is the easiest place to fill them from? (dextron III right?)
I have a 1967 ford mustang coupe. it is whimbelton white and i am switching it from an auto to a five speed with a 331 stroker.
<font size=-1>[ This Message was edited by: knifeman85 on 4/11/03 5:33am ]</font>
knifeman85 is offline   Reply With Quote
04-10-2003, 06:51 PM   #2 (permalink)
67stang
T5...plugs
on the passanger side there are two 3/8" pipe plugs... top is to fill, bottom is to drain.
On the driver side there should be a reverse light plug, a neutral saftey switch plug, and then a rounded star-headed screw which you NEVER want to touch because it releases a gear inside the case.
04-10-2003, 07:57 PM   #3 (permalink)
Billgear
T5...plugs
The switch on the front is neutral safety switch.
Billgear is offline   Reply With Quote
04-10-2003, 10:51 PM   #4 (permalink)
Nastystang
T5...plugs
Dexron/MerconIII
takes 3 quarts.
04-10-2003, 11:22 PM   #5 (permalink)
89gt50
T5...plugs
I found it easiest to just dump the three quarts in through the shifter hole. Of course my console and everything was off at the time, but that shouldnt be much trouble, then the 4 bolts that hold the shifter on.
89gt50 is offline   Reply With Quote
