Distributor gear change?
If you are replacing a hydraulic roller with another hydraulic roller, you shouldn't need to change distributer gears. Assuming the engine originally came with a hydraulic roller) But, if the engine came with a flat tappet cam, and the distributer has a cast iron gear, it will need to be changed.
Hydraulic roller cams came out in mustangs in 1985 with the 5.0 4V HO, and were used on all 5.0 HO's after that.
Good Luck!
