I am in the process of installing a fuel cell in the trunk of my 65'... From the factory it had a drop in style tank... Anyways I made a floor for the trunk in place of the old fuel tank... Now the question is were should I mount the fuel pump with a cell... I was thinking of running the fuel pump in the trunk.. Thought it would be a clean install... Then I thought it may not be that safe having high pressure fuel in the trunk... What is your guys thought on this??? Here is a pic of what I wanted to do...
I could cut a cutout for the sump and run the pump under the car... But the pump I am running is huge... It is the Magnaflow Quickstar 300 w/filter... The pump is very large and placement would be tricky....
Do you guys think it would be safe to run the pump inside the trunk or not... This is a street/strip vehicle.... Mostly drivin on the street though... I am also making a firewall between the trunk and the passanger compartment also... Sorry for the dumb question... Just want to play is safe and do it right the first time....
Billy
65 Mustang fastback 347 stroker
(Next project) 90 notchback 557 stroker
<font size=-1>[ This Message was edited by: billy on 4/15/03 8:46pm ]</font>
