Another rearend question
I can't tell from your post, but here's an idea. Had this happen on my old 8 inch...Sucker would drip oil onto the ground, right off the tips of the u-bolts. I wasn't quite sure where it was coming from, until I noticed one day that when launching the car the whole rear end shifted up/down when power was applied. So, I took one of the u-bolts loose and found that it had chewed all the way through the housing. On both sides. Someone put traction bars on and had a problem with tightening bolts, or something. Anyway, unless you see the lube coming out of the vent hole specifically, might be something to check.
