Anyone use a big block fuel pump in a small block?
I need a dual action vacuum type of fuel pump for my 289 and have not been able to find one. I have a new dual action big block pump which fits late 50's-60's ford big blocks. The levers are not identical, but the pumping action/range and where the lever hits the cam are identical. Only difference being that the 289 pump arm hits the cam at @ a 15-20 degree angle(off engine centerline), whereas the big block pump hits the cam at @ 5 degrees. Other than that, pumps are fully interchangeable. Anyone out there that has the knowledge/ experience or advice on this retrofit? Thanks, Chris
