Need help on final cam choice
It was suggested I call a tech help line. I called Comp Cams, talked to three different guys and guess what? I got four different suggestions. One of them said he was the best Ford techman there. I didn't call Crane or Lunati because I figured the outcome would be the same.
This is the engine combo I have:
D1VE block - block has not been 0-decked, (will 0-deck block next time around.)
TRW forged pistons L2404 - 19cc dish
460 crank kit from P.A.W., balanced, ARP rod bolts, moly rings
Bored .060 over 472ci
D3 heads milled .050
Guides & hardened exhaust seats
PBM brand SS valves installed 2.25 int/1.75 exh
screw in studs & guide plates
3/8 push rods & comp. magnum rockers
ported exhausts & exh bumps removed
Stealth 8012 intake
Milodon 8 qt oil pan
Melling hi-v oil pump
Canton windage tray
C/R is 9.0:1 I know,I know,LOW compression.
The comp cams suggested are:
1. 280H...230/230-.530/.530-LSA 110 degrees
2. XE274H...230/236-.562/.565-LSA 110 degrees
3. X4270H...226/234-.554/.574-LSA 110 degrees
4. 276AH-10...228/236-.547/.547-LSA 110 degrees
This is strictly a street cruiser and will have 3.50 or 3.70 rear gears in a 4,000 lb car.
I would like to get as many opinions about these 4 cams as possible. If you have any other cam suggestions that would fit this combination, feel free to give me that info too.
I really need this help and spring has sprung and I am ready to go.
Thanks Buck
