04-28-2003, 09:42 AM   #1 (permalink)
ScreaminC
Cleveland hydraulic roller cam.
What is needed to run a hydraulic roller cam in a Cleveland? Comp makes a few hyd. roller cams, and the lifters are common with the 5.0's I think.
Anthing special need to be done?
Anyone run a hyd. roller in a Cleve?
Anyone have opinions on hyd. roller cams in general?
ScreaminC is offline   Reply With Quote
04-28-2003, 11:00 AM   #2 (permalink)
allenman85
I am running one in my Cleveland. It is made by Crane.
To run it? I bought the Crane retro-fit kit, also made by Comp, and standard hyd roller lifters. You can find these pieces on Ebay cheap.
That's about it. All said and done? Stick with a solid.
04-28-2003, 11:47 AM   #3 (permalink)
MonsterMach
I am running a Crane mechanical roller with "lock bar" lifters ... with this set-up all you need is the cam and lifters and whatever you will need to get an "adjustable" valve train.
Zero modifications or extra parts for the cam and lifters.[img]/phpBB/images/smiles/icon_tup.gif[/img]
