my new motor
The main thing that stands out is the excessively wide lobe seperation. It will kill the low-end power and midrange. A tighter lobe seperation and FREE flowing exhaust to go along with it will move the powerband down a bit to work better with your converter and give the engine some of that missing lower end power your 302 will naturally be lacking. The duration is a bit much for most ported factory heads as well.
Duration figures that large also want to spin 302's higher than where hydraulic lifters are very efficient (around 6k rpm). A shift to a good, modern solid lifter cam with slightly smaller duration specs and a tighter lobe seperation would pick up serious power across the entire rev range.
If you're using street tires, that converter will probably be fine. If you ever step up to a set of slicks... to really take advantage of them, you'll need a looser unit.
The 3.00 rear gear will have to go!
I would probably recommend the Comp 270S Magnum solid lifter cam for your engine. It's a nice grind, that will better match your existing heads and converter. It will produce more usable power, and make the car feel really strong from around 3000-6300 rpm. It's an 'off the shelf' part, and shouldn't put you in the poor house. It will work WAY better with your combo that what you've currently chosen. (real world experience here)
Be SURE to use the correct springs for any aftermarket cam (installed at the correct height), and be SURE to check rocker arm geometry, and adjust pushrod length for proper sweep and roller placement on the valve stem.
Good Luck!
