351 C questions
I have a '70 Mach 1 with a 351 C engine. It has 4 barrel closed chamber heads, flat top pistons, Torker intake, SSI hydraulic cam .520 lift- int. and ex., 230 duration at 0.50, Rhoads lifters, stock exhaust manifolds, with a 2 1/4" exhaust system. It has a 2.95 first gear T-5 and a 3.25 rear gear in it.It had a 600 Holley vac. sec. carb on it , but it just did not pull like I thought it should. After tinkering with jetting and adjustments on the 600, I put together a 750 DP from four different carbs and whoa what a difference- it pulls hard now. Have any Cleveland guys had similar experiences with DP carbs on Clevelands. I am thinking of putting more gear in it, all I have available is a 3.50 , what do you think?
