Rod between brake pedal and master cylinder
I have a modified brake system on my 65 Mustang. Wilwood heavy duty front, Lincoln V disks on rear, and a Corvette master cylinder. I need a slightly longer version of the rod between the brake pedal and the master cylinder. The rod I have measures 6" from the center of the big hole to the tip. I need 6.5". Ford parts man tells me that a C7TZ-2143-C is 7" long (that will work after a touch up with the grinder) problem is its obsolete. Can anyone tell me what its from or suggest what car I can get a rod from thats between 6.5 and 7.5" long.
