Dipstick ! Thats me.
I've just got a M6007-S58 351W crate engine from Ford Racing. The block casting date is 1994. I've change the water pump (to LH,as viewed looking at tne front of the engine), fitted a new timing pointer and remarked the balancer for ignition timing. The engine will be fitted to my 69 Mach 1. I know I've got change the oil pan to a front sump type (the engine I think, is basically a truck engine with a Performer RPM intake). The question I have is where does the dipstick go? I can drill the blanked off dipstick tube hole in the front timing cover (as stated I've got change the oil pan anyway), but where is the dip stick tube meant to go on these later 351's ?
2nd question, the engine is fitted with a Duraspark II distributor, I need to get an ignition control unit that is compatable with the magnetic pickup fitted to this dizzy, any suggestions ?
Rob
