351C to 460 conversion ... W/ Toploader
[img]/phpBB/images/smiles/icon_cool.gif[/img]the small block and the 460 use the same top loader input shaft, the FE's use a shorter one. as for using a top loader over a T5, that would depend on how the small block in you cougar is built, and what rear gear you are pulling. if a 2.80-3.00 gear, or are making 350+hp use the top loader. if pulling a 3.50-4.11 gear and making under 350hp then the T5 is good.
