07-07-2003, 02:26 AM   #1 (permalink)
Fastback66
t04 turbo
How much power can a single t04 turbo support? It would be on a 302 pushing 350-375 hp N/A. Also what carb could i use?
Fastback66 is offline   Reply With Quote
07-07-2003, 05:00 AM   #2 (permalink)
rbohm
t04 turbo
[img]/phpBB/images/smiles/icon_cool.gif[/img]a T04 can support about 500-600hp, perhaps a bit more. get your compression right though, otherwise it will blow th ebottom end out of the block.
07-07-2003, 09:40 AM   #3 (permalink)
mavman
t04 turbo
about 500 HP, depending on which one you use (t04e, to4b, etc) Any more than that and they tend to blow a lot of hot air. There are better choices than a T04....such as a late model (99-02) powerstroke turbo. Bigger compressor and small turbine for quick spooling....and best of all, a integral wastegate.
07-07-2003, 03:23 PM   #4 (permalink)
Fastback66
t04 turbo
Where and how much could i get one of those turbos Mavman?
Also the reason about the t04 is i can get one for free.
<font size=-1>[ This Message was edited by: Fastback66 on 7/8/03 2:34am ]</font>
07-07-2003, 04:02 PM   #5 (permalink)
DynoTom
t04 turbo
I love the sound of my turbo on my 2000 Excursion!
It's a really powerfull unit to have![img]/phpBB/images/smiles/icon_tup.gif[/img]
Whoooooooooooooooooooooooooooooshhhhh!!!!!
07-07-2003, 05:53 PM   #6 (permalink)
mavman
t04 turbo
well...a good place to find one is a local scrap metal recycler, ebay, or just keep your eyes open for one...they pop up every now and then. Make sure you get the later one (99-02) as the early ones (95-97) are smaller and have larger turbine housings. They (early ones) will work but they spool a bit slower, and most importantly do not have a integral wastegate. You'll want a wastegate to keep boost in check....the early powerstroke turbos can make over 22 psi, and the T04B can make around 25-27.
