07-22-2003, 03:49 PM   #1 (permalink)
custom300fe
Brake bleeding procedure. :-?
Is there a set way to bleed a new brake syste?. I've changed to disc brakes on the 57 and changed all lines, cylinders and installed the prop valve. I have bench bleed the master cylinder. Now can I gravity fill the lines to start or does it have to be pressure bleed?
Gerry[img]/phpBB/images/smiles/icon_confused.gif[/img]
custom300fe is offline   Reply With Quote
07-22-2003, 04:55 PM   #2 (permalink)
anthonydalrymple
You should be able to let it gravity feed. Better yet, get a buddy & just bleed the whole system. Start at the wheel farthest from the mastercylinder & work your way to the closest. I usually do it a couple times until i see no air nor old dirty fluid.
anthonydalrymple is offline   Reply With Quote
07-22-2003, 05:08 PM   #3 (permalink)
jeffstar
I just got a set of speed bleeders and really like them. Someone posted their website a week or so back.
07-22-2003, 05:48 PM   #4 (permalink)
69XL
Another vote for gravity feeding the lines, and bleeding them - starting with the passenger side rear.
I you are doing this alone; you can cut 2x4 to use between the pedal and the wheel. Pump the pedal place the 2x4 in. Top off the reservoir, the bleed the wheel cylinder/caliper.
It is good to reproduce this procedure in a few days for a complete system change as you are doing.
69XL is offline   Reply With Quote
