07-28-2003, 02:58 AM   #1 (permalink)
growlin351w
Mechanical fuel pump VS. Electric fuel Pump
Will changing from the Holley 110 GPH mechanical fuel pump to the Holley blue 110 gph electric fuel pump make any horsepower difference on my 351w? Change my ET's?
please let me know thanks.
growlin351w is offline   Reply With Quote
07-28-2003, 06:55 AM   #2 (permalink)
Livermore Dave
Yes there will be some horsepower available with the electric unit, with each unit rated the same,and unless you are a class racer that needs every bit of power available,the dependability and convience the mechanical unit offers,it would be the choice for me...Dave.
Livermore Dave is offline   Reply With Quote
07-28-2003, 09:30 AM   #3 (permalink)
ckelly
You'll go faster as you try to drive away from the noise that Holley Blue will make. There is a little HP to be made, but not much. It'm more convinence factors - you can shut off an electric pump. That lets you drain the carb for tuneups and for theft deterrent. You can also reroute your fuel line away from engine heat sources.
07-28-2003, 02:37 PM   #4 (permalink)
growlin351w
The Holley blue wont change my ET's much will it?
07-28-2003, 02:52 PM   #5 (permalink)
n2omike
If you have a street car, and it doesn't make over 500hp, you don't NEED an electric pump.
Mechanical pumps are much more quiet and reliable (not to mention less expensive) than electric units. They are my overwhelming first choice for regularly street driven cars.
You're not going to gain any significant power by switching to an electric pump if the mechanical is doing it's job of keeping the bowls filled with fuel. [img]/phpBB/images/smiles/icon_wink.gif[/img]
Good Luck!
07-28-2003, 02:52 PM   #6 (permalink)
SCOTT
Only way to tell is an o2 reading on the dyno. Unless you running too lean the motor doesn't care which pump you use. Might be a very slight differenct due to fuel heat, but unless your John Force that wont matter. As far as hp used/wasted to turn the mechanical pump cam......I doubt it could be measured and repeated consistantly to even have an answer.
SCOTT is offline   Reply With Quote
07-29-2003, 06:23 PM   #7 (permalink)
kosmo7
There's an additional concern too - the Holley Blue needs a pressure regulator, since it's output pressure is in the 14 psi area. The reg they supply is a total POS, by the way - It really needs a return-type regulator and a line back to the tank.
You may also wish to know that the quality control in the Blue pumps has slipped over the last few years - I currently have one back at Holley to find out why the pressure goes to 3 psi when the pump gets hot.
kosmo7 is offline   Reply With Quote
07-29-2003, 10:30 PM   #8 (permalink)
bluestreek
I run a Carter HV mechanical pump on my 331 and have yet to run it out of gas. As a matter of fact, I have to set the floats low or it will over feed the 750 HP carb. If your fuel flow gives up, you will definately feel it!! At the top of the gear the car will feel like someone is hitting the brakes.
07-31-2003, 08:47 AM   #9 (permalink)
ville
I am running a Carter 110 pump as well.Works fine on the street and really has the capacity to feed 530 hp + at 6500 rpm.Only thing; if you dragrace the car with slicks the underpressure generated by the pump may not be enough on the starting line causing acute fuel delivery problem..thatīs what happened to me.On the street it is totally ok.
ville is offline   Reply With Quote
07-31-2003, 12:58 PM   #10 (permalink)
bluestreek
Ville,
Fuel pump problems usually show up in the top of the gear at the strip and not off the starting line. I would point my finger at the rear carb jets or fuel pickup getting uncovered before blaming the pump. JMO
