They sure are BMFs! Kaase stated they don't need exh valve relifs and the intakes should clear up to
256@.050 solid roller. Now with the intake valve being moved closer to the intake flange that means the inline valve intake valve reliefs in std pistons will not even come close to being in the right place yet he used these heads on a crate 392 meaning he didn't need any vlave reliefs for up to 256 duration at .050 solid rollers. Much like the pistons for the Motorsport N-351 head that has no valve relifs I think those pistons would be perfect to use and if a relief is needed after all, you can rent the Isky relief cutter like I do and make your own reliefs cheap. The price of these heads and the fact they use standard type roller rockers makes these heads affordable to me compared to the Victors which require shaft rockers and the Kaase heads have the Dart header pattern. I can use these in my car! Hmmmm, sell the A-429s, Victor 4500 intake, and 532 stroker kit.....[img]/phpBB/images/smiles/icon_razz.gif[/img][img]/phpBB/images/smiles/icon_spin.gif[/img][img]/phpBB/images/smiles/icon_tup.gif[/img]
