11-07-2003, 12:01 AM   #1 (permalink)
birddog
316 stroker/pistons
I have a 316 stroker crank, will regular pistons have too much skirt for the stroke?
birddog is offline   Reply With Quote
11-07-2003, 11:06 AM   #2 (permalink)
jetnoise
316 stroker/pistons
Whats the throw/stroke on the crank?
11-07-2003, 11:46 AM   #3 (permalink)
tonys10sec306
316 stroker/pistons
You are going to need custom pistons. i have 5.40 rods in my 306 i needed custom pistons.you might can find a off the self piston with the right combination that you need for the rod/stroke you have.i saw this 324 stroker comb with a stock crank offset-ground to 3.125 stroke. 5.400 chevy rods and a off the shelf chevy piston. so you might can find a off the shelf piston
80 cobra high 10's long rod 306 all motor. iron heads,flat tappet cam, mufflers and d.o.t tires
84 mercury capri 308
97 merecury mountaineer 5.0
<font size=-1>[ This Message was edited by: tonys10sec306 on 11/7/03 11:47pm ]</font>
11-07-2003, 10:07 PM   #4 (permalink)
birddog
316 stroker/pistons
would'nt 331 stroker sized pistons work? Or am I missing something. (This is my first engine build)
11-07-2003, 10:16 PM   #5 (permalink)
birddog
316 stroker/pistons
btw rods are 5.40
11-08-2003, 01:44 AM   #6 (permalink)
casadepunklife
316 stroker/pistons
I'm pretty new myself, but my thinking is that pistons designed for a 331 (3.250 crank) would give you much lower compression. Since you're using the same rod length (5.4&quot[img]/phpBB/images/smiles/icon_wink.gif[/img] with less stroke there will be more open space above the piston when it's at the top of its stroke. You want a taller piston to acheive the same compression ratio I believe.
casadepunklife is offline   Reply With Quote
