MAE "McCanes Automotive Enterprises" (sets up shop at the big Columbus swap meet) has great deals on Motive Gear rear end kits.
For $239, they offer a MASTER KIT that included the R&P, all four Timkin bearings, spacers to set pinion depth, gear marking coumpond, seals, o-ring, gasket, crush sleeve, loc-tite, ring gear bolts, etc. It comes with EVERYTHING needed to swap a ring and pinion. The kit uses a Motive Gear R&P, which seems to have gained a LOT of popularity lately. To upgrade to a solid pinion spacer is an extra $10. To upgrade the pinion bearings to those used with the Daytona pinion support is an extra $14. And to upgrade to the longer Trac-Loc R&P bolts is a few more bucks.
I purchased a kit recently, and had great luck with it. When I had questions, he was easily reached on both the phone AND email. The service was FIRST RATE.
They offer the following ratios at this price... 3.25-3.50-3.70-3.89-4.11-4.56-4.86
They also offer Trac-Loc clutches at a good price. It comes with all the fibers, steels, and the combo plate. Mine were stamped "Kevlar, made in USA" The price was only $43.99 for the set.
I HIGHLY reccommend MAE. You are supposed to be able to purchase items from their website, but you'd probably have better luck on the phone. (the site still needs to be streamlined a bit)
Here's the R&P master kit
http://www.andale.com/stores/sf_item...485&mode=1
www.maeracing.com
606-757-3221
maeracing@ekns.net
Good Luck!
