11-29-2003, 08:24 PM   #1 (permalink)
growlin351w
Difference between 69 351w 4bbl heads and 2 bbl heads?
What is the difference between 69 351w 4 bbl heads and 2 bbl heads?
please let me know thanks.
growlin351w is offline   Reply With Quote
11-29-2003, 08:34 PM   #2 (permalink)
FordMatt
There is no difference.
FordMatt is offline   Reply With Quote
11-29-2003, 09:37 PM   #3 (permalink)
n2omike
As far as 69-70 (C9OE and D0OE) heads, there is no difference.
After that, 351W heads got larger combustion chambers, then smaller valves, etc. Eventually, the heads were no different than 302 heads.
11-29-2003, 09:41 PM   #4 (permalink)
Dave C
The guys are right. No difference in heads. The 4V was rated at slightly higher hp duw to higher compression. The 4V engines had flat tops with valve reliefs vs the 2v having a slightly dished piston. 10:1 vs 9.5:1
Later,
David Cole
Dave C is offline   Reply With Quote
