11-30-2003, 08:13 PM   #1 (permalink)
Foxbodystang
8.8 cougar rear into fox stang w/ t-bird TC rear disc conv. or 5 lug conv. with rear disc
im planning on putting an 8.8 rear into my fox body stang out of my 88 cougar xr-7 im thinking the rear end is a little bit wider which dont really matter itll just handle a litte better and if the tires stick out oh well. what i am trying to figure out is if the rear end is longer and what is the easiest way to do a rear disc brake conversion. i would perfer to do the disc brake conversion and the 5 lug conversion at the same time ( to save money and time ) so i was wondering is there any part mixing and matching that i can do to convert to 5 lug disc brakes in the rear. im also planning on installing the sn95 spindles and brakes on the front to ne one that can help thank you
Foxbodystang is offline   Reply With Quote
11-30-2003, 08:36 PM   #2 (permalink)
1 Bad 88 GT
Use SN95[94-98] parts for the rear swap it's a direct swap.
<font size=-1>[ This Message was edited by: 1 Bad 88 GT on 12/1/03 8:40am ]</font>
