Limit on Stock Fuel System
Need a little help -
Here is what I have:
89 LX 5.0 -
Mods -
Block bored to 306 - B303 Cam - Heads were milled 10 over during overhaul - Cobra Intake - BBK Headers - 73 mm Mass Air Meter - SuperChip - H - Pipe - Flowmaters - Pulleys - 3.73 REar End ---
The Fuel Pump is a stock replacement - Injectors are Stock.
This is not my only car, however, I still consider it a daily driver. - ( I probably drive it 3-4 times a week avg.)
My question is - If I port the heads or buy aftermarket heads, will I have to upgrade the fuel system - Pump, Injectors..etc... - or will I be ok? - or do I just need a pump and/or pressure regulator. - I would like to por tthe heads but if I need to make several other mods, I would like to know. - I have asked friends and several mechanics and received answers from NO - to yes, I need new injectors, pump, regulator --- and everything in between tthe two answers. - - Any input would be great. - I am not our to the track every week and I really like the way the car runs now however, the valve guides are leaky and while I had the heads off, I figured, why not port them a little? - ( Not myself ) -- Thanks, Sam
<font size=-1>[ This Message was edited by: samferd on 12/13/03 10:58pm ]</font>
