12-13-2003, 04:48 PM   #1 (permalink)
rhoney
Mighty Demon
Thinking of changing from 4776 holley to a 650 mighty demon, is this worthwile as is $1000 aussie[img]/phpBB/images/smiles/icon_eek.gif[/img]. Runs fine now just looking for more HP @ Torgue everywhere[img]/phpBB/images/smiles/icon_wink.gif[/img]
rhoney is offline   Reply With Quote
12-13-2003, 05:11 PM   #2 (permalink)
mstngjoe
Mighty Demon
You might consider just swapping in a Proform main body. About $99 USD from Summit.
http://www.proformparts.com/catalog/carb.html
Main bodies, base plates, meter blocks & whole carbs.
331, SCAT crank & H-beams, SRP flat tops, AFR 185, Stealth, Proform 750 (awaiting install!), Buddy Rawls custom cam & a few more go fast goodies. [img]/phpBB/images/smiles/icon_smile.gif[/img]
<font size=-1>[ This Message was edited by: mstngjoe on 12/14/03 5:13am ]</font>
12-13-2003, 06:57 PM   #3 (permalink)
bluestreek
Mighty Demon
Spend your money on a good solid cam instead. When I ran a similar combo to yours, I only gained 1 mph going from a 600 to a 650. Even a 750 VS didn't help. After switching to a Comp 282S cam, I gained 4 mph. Money well spent!
12-14-2003, 12:39 AM   #4 (permalink)
rhoney
Mighty Demon
Am happy with current airflow, but thought would pick up power due to better atomisation and distribution ( boosters and venturis sure look trick on a demon)[img]/phpBB/images/smiles/icon_spongebob.gif[/img]. Ps am running Erson Hi-Flow 1H and like the current power spread pulls hard from 3100 (where convertor now stalls after ditching the torker2[img]/phpBB/images/smiles/icon_lame.gif[/img] for a crosswind intake , used to stall at 3000) any suggestions for solid cam that will live with this convertor but will spin strong to 6500-6800
12-15-2003, 12:59 PM   #5 (permalink)
TechAtBG
Mighty Demon
A 650 Mighty Demon should make a noticable gain over a 600 Holley. The 650 Mighty Demons flow 753 CFM at 1.5" of vacuum, but still use the smaller venturi giving you better atomazation of the fuel. In Australia you can get one through Victorina Performance.
TechAtBG is offline   Reply With Quote
12-15-2003, 01:25 PM   #6 (permalink)
mstngjoe
Mighty Demon
Tech:
You get around....[img]/phpBB/images/smiles/icon_wink.gif[/img]
12-15-2003, 02:39 PM   #7 (permalink)
mstngjoe
Mighty Demon
On 2003-12-13 17:43, Karl wrote:
The Proform body is listed for the 650 cfm 4777 and bigger holleys only.........</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
My bad.[img]/phpBB/images/smiles/icon_frown.gif[/img]
12-15-2003, 04:35 PM   #8 (permalink)
TechAtBG
Mighty Demon
On 2003-12-15 13:25, mstngjoe wrote:
Tech:
We try....
12-15-2003, 04:54 PM   #9 (permalink)
ckelly
Mighty Demon
I looked at your setup - try the Mighty Demon before the ProForm. The ProForm bodies flow near 900 and your combo doesn't have near the gear and stall to host a modified 750DP that flows 900CFM.
12-15-2003, 05:57 PM   #10 (permalink)
mstngjoe
Mighty Demon
On 2003-12-15 16:54, ckelly wrote:.....The ProForm bodies flow near 900......</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Huh?[img]/phpBB/images/smiles/icon_confused.gif[/img] That's not the 750 body? Is it? If so how flowed.
331, SCAT crank &amp; H-beams, SRP flat tops, AFR 185, Stealth, Proform 750 (awaiting install!), Buddy Rawls custom cam &amp; a few more go fast goodies. [img]/phpBB/images/smiles/icon_smile.gif[/img]
<font size=-1>[ This Message was edited by: mstngjoe on 12/16/03 5:57am ]</font>
