Brakes need fixing?
First off, check the fluid level. If it is low, fill it and check the level again in a week. You can also check the rubber soft lines for cracking/leaking. It sounds to me like youre not building pressure, and I would suspect the master cylinder first. Look for leaks around the master cylinder where it bolts to the booster. If the cylinder is bad, it isnt a really hard part to replace. Midas WILL charge an arm, leg, first born, left testicle, etc. for any work they do.
