01-29-2004, 02:16 AM   #1 (permalink)
macoliver
351m
One of our mudracing sanctions changed there rules to NO BIG BLOCKS. they put a 377ci limit on the class. Now they are saying the 351M is not legal because Ford says they are a big block. I would appreciate any info on this. Thanks Mac
macoliver is offline   Reply With Quote
01-29-2004, 02:44 AM   #2 (permalink)
deleted2
351m
They are not. A big block is a FE or 385 series engine. This is a 335 series engine. They need to just put a cap on the size, too much controversy. Maybe they just want to ban canted valve engines.
01-29-2004, 07:22 AM   #3 (permalink)
mavman
351m
They did the same thing here, also stating that the M engine was a big block. Wrong! They also used the 377 limit after they found out that the M's were small-blocks so people would quit using 400s. The clevelands rule the class!
Last I heard they were going to revise it again which would remove all splayed-valve heads and use an inline-valve head rule.
01-29-2004, 12:12 PM   #4 (permalink)
1 Bad 88 GT
351m
Ford has never classified the 351M/400 as a big block. As an aside a Chevy 400 has always been called a small block.
BTW would a CLevor be legal.
01-29-2004, 01:21 PM   #5 (permalink)
Radchero
351m
Fight it! Remind them 351M/400 has the same bore spacing as all small block Fords!
Radchero is offline   Reply With Quote
01-29-2004, 01:35 PM   #6 (permalink)
dodgestang
351m
You are up against it.
IITC the 400 and 351m have the BB bell housing bolt pattern so they can make a valid point. On the plus side, you can still use a 351c since it has the small block bolt pattern, get the benefit of the canted valves and stroke it out to exactly 377 cubes [img]/phpBB/images/smiles/icon_wink.gif[/img]
dodgestang is offline   Reply With Quote
