01-29-2004, 03:58 PM   #1 (permalink)
6t6cyclone
trans cooler
would routing fluid lines through old ac condenser in front of radiator work the same as a transmission cooler?
6t6cyclone is offline   Reply With Quote
01-29-2004, 04:19 PM   #2 (permalink)
1967galaxie
trans cooler
Yes I believe so. But this would increase the temp of the air thats being drawn through the rad. Would work better if mounted behind the rad. Also if you drive in the winter you wiil have problems getting your trans up to operating temp. Remember too hot is bad and too cold is also bad.
1967galaxie is offline   Reply With Quote
01-29-2004, 06:20 PM   #3 (permalink)
64 TBOLT
trans cooler
http://www.network54.com/Forum/threa...eid=1066766588
