02-14-2004, 08:00 AM   #1 (permalink)
fordmanz
Motor swap to a 1988 ford truck needed!!!
I have a 1988 ford F-150 4WD with a 302 in it that has gone bad.I also have a 1987 mustang 5.0 HO motor.Can I use this motor by using the different firing order.Also do I have to use the truck intake.I need advise ASAP to get my truck back on the road.
fordmanz is offline   Reply With Quote
02-14-2004, 10:57 AM   #2 (permalink)
deleted2
I've seen it done. The injectors fire at the wrong time but it doesn't seem to matter. You can change the cam & get the old firing order if ya wanna.
02-14-2004, 01:48 PM   #3 (permalink)
fordmanz
So it should be a easy swap.I would rather keep the ho firing order.
02-14-2004, 05:12 PM   #4 (permalink)
deleted2
Should be an easy one. I did an HO in a LTD last year & it was ok.
02-14-2004, 09:17 PM   #5 (permalink)
fordmanz
Which intake do I have to use?The HO one or the truck one.
02-14-2004, 09:34 PM   #6 (permalink)
deleted2
Use the HO lower & the truck upper
