Slick size??
Assuing a 28" tire normally, a 26" tire will give you an effective 3.76 ratio. A 29" tire will give you a 3.37 effective ratio. The converter should be designed to get the engine up on the cam and you gear should be picked to keep the engine in whatever that range is for max ET. Being that you may still need to drive around, compromise is what you end up with.
Another thought: 3500 stall with a tall tire and a 3.5 gear means that you'll be under the stall rating of the converter most of the time, even on the highway. That means extra heat being generated. If it's a true 3500, be sure you put a big trans cooler on it.
