04-19-2004, 07:24 AM   #1 (permalink)
64 TBOLT
O2 sensor
how does a engine act if the O2 sensor is bad[img]/phpBB/images/smiles/icon_confused.gif[/img]
04-19-2004, 08:19 AM   #2 (permalink)
Helmantel
O2 sensor
Fuel consumption will go up a lot.
The O2 sensor's output is about 0.8 V when rich and 0.1 when lean. The ECU tries to keep the value in between by adjusting the fuel flow. When it's broken, the sensor will give a low voltage (I suspect) all the time, so the ECU thinks the engine runs lean and tries to enrich the mixture.
Helmantel is offline   Reply With Quote
04-19-2004, 06:27 PM   #3 (permalink)
64 TBOLT
O2 sensor
we pluged it in to a engine anaylzer and everything seemed to check out ok(no codes) but the O2 sensor read rich
04-20-2004, 12:00 AM   #4 (permalink)
ChicoB
O2 sensor
I had a sensor go out on my jeep after a head rebuild. I took it into my favorite shop and he instantly knew it was bad just by looking at it.
It had a telltale light grey-kinda-powder-like coating all over the electrode. He said it was from silicone contamination, most likely from RTV on the new intake gaskets.
04-20-2004, 08:04 PM   #5 (permalink)
64 TBOLT
O2 sensor
hoeing out the converter helped a whole bunch.It had two but now has one(empty)OH YA this is on a 94 xplorer 4.0
