04-28-2004, 06:24 PM   #1 (permalink)
wildosvt01_OLD
351C/FMX swap to AOD....In a 73 Torino
I just bought a AOD.I know the basic things I will need to put the AOD in like floor shifter new trans lines etc.What I am wondering is what flywheel will I need,If any.And what can I do for the kickdown.I am looking for any suggestions to prepare me for some recycle yard searching.[img]/phpBB/images/smiles/icon_bow.gif[/img]
Will the stock flywheel work?
Thanks for any thoughts or knowledge.
Wildo..[img]/phpBB/images/smiles/icon_bow.gif[/img]
wildosvt01_OLD is offline   Reply With Quote
04-28-2004, 08:55 PM   #2 (permalink)
allenman85
The flywheels are almost identical. I personally did not have a problem reusing the FMX flywheel. Others may say differently.
Look for an AOD yoke (shorter than C4!!) while you're out and about. You can re-use the stock driveshaft.
You might have to fabricate some mounts as the AOD is tight against the factory mount.
The shifters *are* different for AOD vs FMX (about 5 degrees per detent).Windsor-Fox can help you out there.
Look for a carb kickdown setup from a factory car (Crown Vic '85/'86?).
Happy hunting
Holley
