05-09-2004, 08:14 PM   #1 (permalink)
Joe30690
Suggestions for getting my 306 into the 11\'s.
hey i'm putting together a 306 motor. i have a short block with some dome pistons, Scat rods, stock crank, and a dss main girdle. I also have a victor jr. manifold and a holley 650dp with a proform main body for the top end. What should i be looking at for heads and cam (mechanical roller) if i wanted to put my mustang in the 11's? I'll be using a C/4 with a 10" 3,500 stall converter and a 4.10 gear with a 26" tall tire. Thanks a lot in advance.
Joe30690 is offline   Reply With Quote
05-10-2004, 12:29 AM   #2 (permalink)
Stanley Superior
A set of AFR 165's would get you there easily! But be sure your piston tops match the shape of the combustion chamber or you may run into problems.
Stanley Superior is offline   Reply With Quote
05-10-2004, 10:27 AM   #3 (permalink)
tonys10sec306
you dont need a mech roller to run 11's. my old 306 with a set of mild ported 70 351w heads and a flat tappet cam. the can ran 11.70's@113 with a 1.58 60 in a 3100 pound car in street trim.
80 cobra high 10's long rod 306 all motor. iron heads,flat tappet cam, mufflers and d.o.t tires
84 mercury capri 308
97 merecury mountaineer 5.0
<font size=-1>[ This Message was edited by: tonys10sec306 on 5/10/04 9:28pm ]</font>
tonys10sec306 is online now   Reply With Quote
