05-19-2004, 07:19 AM   #1 (permalink)
buscg
belt and pulleys
Im putting together a 302 and only using a water pump, alternator, and the crank pulleys. I have a lot of miscellaneous pulleys but all the crank pulleys I have have 3 or better belt positions. Can anyone tell me what they are using pulleys from and if anyone has pictures it would help out alot. Thanks, by the way Im doing V-belt.
buscg is offline   Reply With Quote
05-19-2004, 08:31 AM   #2 (permalink)
ScreaminC
belt and pulleys
Well, I looked for a long time and the only pulleys I found at local j-yards had the water pump tensioned off of the power steering. Like you, I do not run power steering so I ended up using a crank pulley off an older 302 to run the alternator and then running the water pump with a Moroso Electric Drive kit.
ScreaminC is offline   Reply With Quote
05-19-2004, 09:23 AM   #3 (permalink)
ckelly
belt and pulleys
In the early days, I fabbed a bracket to use an AC idler on the PS side of the water pump to take the slack out of the WP-crank belt. It worked, but looked a little hokey. That's why I switched up to the 6 rib setup.
05-19-2004, 11:15 AM   #4 (permalink)
jon
belt and pulleys
some of the old 289 cars had just an alternator and water pump set up on them -- with a single belt - probably 65-66 mustangs --saw an old fairlane the other day with it --- but beware of some differences in balancer length and bolt pattern (3 or 4 bolt)
jon is offline   Reply With Quote
05-19-2004, 04:54 PM   #5 (permalink)
buscg
belt and pulleys
yeah that might be a problem. Im using a late model block with 4 bolt so all the old crank pulleys are 3 bolt. I was thinking about seeing if a machine shop could re-drill a 3 bolt. I wish someone just sold the kit.
05-19-2004, 05:18 PM   #6 (permalink)
PhatFalcon
belt and pulleys
Might just go with March pulleys if you can stand the price. They have a one V-belt setup that I used on my Falcon with just the alt, WP, and crank.
05-19-2004, 05:29 PM   #7 (permalink)
chas319
belt and pulleys
my 82 f150 302 came with 3 row crank 2 row waterpump and single alt. plus ac and p/s.
the one belt can go from the crank to the waterpump then to the alt. ive seen it before just cant remember.
chas319 is offline   Reply With Quote
Hays Clutches
