05-25-2004, 02:24 AM   #1 (permalink)
83coupe408W
408 stroker front lobe of crank hitting oil pump.
Does anybody know if there is such a thing as a low profle/offset oil pump for a 408W. The front lobe on my crank is hitting the oil pump. I cant see no way to make this work. somebody please help???[img]/phpBB/images/smiles/icon_confused.gif[/img]
83coupe408W is offline   Reply With Quote
05-25-2004, 02:33 AM   #2 (permalink)
fogged408w
You need to post more info....What crank and what oil pump do you have?
So your saying that the front crank throw is hitting the oil pump?
I had to grind the block "alot" by the oil pump mount and alittle on the "melling HV" oil pump for my 408 with an eagle crank.
If you cant remove enough metal from the pump, I'd have the crank throw turned down at the machine shop.
05-25-2004, 04:41 AM   #3 (permalink)
Mario428
My brothers 408 also needed the oil pump ground slightly, did no harm and was easy to do.
05-25-2004, 03:28 PM   #4 (permalink)
R Code
Same deal on my 400 cranked 422 and RPM's Scat cranked 393. Just ground on the oil pump housing to create the clearance.
05-25-2004, 05:08 PM   #5 (permalink)
RajinCajun
Yes this is normal. What type of pump you using???? For this problem just grind the oil pump a little thats all you need to do. I use a melling HV pump and do not run into this problem M-83HV is the part number....
RajinCajun is offline   Reply With Quote
05-26-2004, 12:15 AM   #6 (permalink)
83coupe408W
I am just using a the old standard pump right know trying to get everything to work. I go ahead and start grinding on it for a practice run,and get the Hi-volume Melling ordered.
Thanks for the info[img]/phpBB/images/smiles/icon_smile.gif[/img]
This is the only place I could find help after two weeks of phone calls.
05-26-2004, 12:28 AM   #7 (permalink)
fogged408w
Well stick around, this is the best ford small block forum on the net!!!!!
