297 HP @ 6200 and 307 torque @ 4100 at the wheels. So if I adjust for 20% loss, I end up with 371 HP and 383 ft/lbs torque at the flywheel. EA 3.0 predicted the mufflered engine would be 380 HP and 391 torque (using 410 cfm flow spec of the mufflers) so it was off by less than 10 HP... very accurate! Open header prediction is 417 HP and 418 torque so if its high by 10 like it was for the mufflered version, that would put it at 407 HP and 408 torque...that would be fantastic!!
I had dynomax super turbos on it and the carb has not been tuned (670 holley avenger taken right out of the box) and the timing may not be optimum. I gotta feel that the heads are flowing pretty well to get peak HP at 6200 and it hasn't even been tuned yet!
I took it to Brothers Performance in Corona, Ca. They could only dyno...they could not monitor air/fuel or timing.
It definitely feels like it's putting out a lot of power.
By the way, got the car weighed at the scales...3100 lbs on the nose.
Here is a pic of the completed car.
