06-25-2004, 01:52 AM   #1 (permalink)
decayforme999
what is needed for a tranny change to use inline 4 tranny with my v8?
what is needed for my tranny its a t-5 for a 91 Lx.bellhousing is a must and what else?? help please
decayforme999 is offline   Reply With Quote
06-25-2004, 07:41 AM   #2 (permalink)
Beoweolf
Don't do it! Low gear is too low, torque rating is too low. Transmission is too weak.
Check into the swap a little closer and you will find it is widely advised that under no circumstances is this a recommended swap. Check below...engine, torque rating, 1st gear ratio. Even in the early years, the 302 (5.0 liter V-[img]/phpBB/images/smiles/icon_cool.gif[/img] the torque rating was 300 ft/lb and they needed improvement, the 4-cyl (2.3 liter)transmission is only rated at 240 ft/lb capacity.
204 Service 85-89 Mustang 5.0 300 3.35 1.99 1.33 1.00 0.68 3.15 7 7.18 0.668
207 Factory 91 Mustang 2.3 240 3.97 2.34 1.46 1.00 0.79 3.70 7 7.41 0.59
208 Factory 92-93 Mustang 5.0 300 3.35 1.99 1.33 1.00 0.68 3.15 8 7.18 0.668 d
209 Factory 92-93 Mustang 2.3 240 3.97 2.34 1.46 1.00 0.79 3.70 7 7.41 0.59
<font size=-1>[ This Message was edited by: Beoweolf on 6/25/04 9:28pm ]</font>
<font size=-1>[ This Message was edited by: Beoweolf on 6/25/04 9:29pm ]</font>
06-25-2004, 07:55 AM   #3 (permalink)
labzerpa
My buddy upthere is right, you should not put a 4 cyl t-5 with a V8. However, the hardware youŽll need is the same. Basically youŽll need a 5.0 bellhousing, preassure plate, flywheel, disk, throw out bearing, and clutch fork.
labzerpa is offline   Reply With Quote
06-25-2004, 12:46 PM   #4 (permalink)
decayforme999
I plan on changing the tranny next year and the engine when i get it running. I don't plan on dumping the clutch in the first 10 minutes of it being done.
06-25-2004, 02:18 PM   #5 (permalink)
pedal2themetal45
HI
It don't matter if you dump the clutch 10mins. or 10yrs later the 4cyl. tranny won't last on a v8.[img]/phpBB/images/smiles/icon_frown.gif[/img] Even if you never dump the clutch the tranny won't last on V8 power.
Tim[img]/phpBB/images/smiles/icon_spin.gif[/img]
06-26-2004, 06:45 PM   #6 (permalink)
TurboCoupe50
Playin Devils advocate, I have heard of the 4 banger trannys being used with good sucess(no way I would try it though). Neighbor down the street has one in a '96 V6 Stang, his kid has been driving it for 8-9 months, so far no prob. BTW you'll need a late '80s pilot bearing for a Probe to make it work.
TurboCoupe50 is offline   Reply With Quote
06-27-2004, 03:02 AM   #7 (permalink)
rbohm
[img]/phpBB/images/smiles/icon_cool.gif[/img]yes the 4 cylinder tranny will work on the V6, and the early inline sixes, even hopped up, BUT it will not last behind a V8. there is way too much torque available at the flywheel with the V8, and the 4 cylinder tranny will break. heck even the V8 trannies break behind hopped up V8's. do oyu really thing the 4 popper tranny will last?
06-27-2004, 05:49 AM   #8 (permalink)
labzerpa
Well, IMHO I do not think itŽs the best of swaps, but when confronted with not having my stang runing because a sincro was bad, I put a 4 cyl turbo T-5 on it and never thought twice about it. I used it and abused it with my stock 302 for 2 years until I found a 8 cyl T-5, and never had a problem....and for me the low gears were a plus off the line. I still do not think you should do it if you got the choise, but if not, just stay stock and donŽt use slicks.
06-27-2004, 01:53 PM   #9 (permalink)
TheGmKiller331
This to me is along the same lines as using the 7.5 rear end with a modified V8.Some say NO WAY IN HELL and others have had good luck.
I know a few guys using the 2.3 T-5 from the T-Bird Turbo coupes and so far its been ok.
Its up to you man.But i agree with tyhe last comment of not using slicks.
If i were you and had to do this it would be a go between tranny just as tranny i used to get me up and running.
TheGmKiller331 is offline   Reply With Quote
06-27-2004, 01:59 PM   #10 (permalink)
deleted2
The T-5 from my old SVO is in a mid 12 second GT right now &amp; has been for a year. Albeit a World Class T-5 he had a 4 popper one in there for a year.
