The trac-loc is an old, clutch type design. The clutches wear out quickly, and need replaced on a regular basis. One or two one wheel burnouts, and the clutches are toasted.
My advice is to go to the aftermarket. If drag racing is what you are interested in, go for the Detroit Locker. Yes, Tractech (the makers of the original Detroit) make an 8" version. They also make a 'Torsen' type unit that uses helical gears instead of clutches. These are GREAT street and roadrace units. They don't hold up to WFO launches on slicks with a stickshift, but neither do trac-locs, or their original 28 spline axles. (8 inch rears don't use 31 spline axles) This Torsen type is also made by Tractech, and is called the Trutrac... and there is one available for the 8" rear. I know the 9" version is VERY reasonably priced.
http://www.tractech.com
I believe
http://www.maeracing.com sells both units. You'll want to call them to be sure and to check stock. They have very good prices on them. I'm sure Randys Ring and Pinion also carries these units.
http://ringpinion.com
If the ring and pinion are not replaced, installation is relatively easy. Once the third member is removed, clean the unit with gasoline to remove all the gear oil. This will allow you to get an accurate check of the backlash. Write this down, and replace the open diff with the new one. Reset the backlash to the original specs and reinstall. The pinion will not need removed, so shims and pinion depth don't need messed with.
Good Luck!
Good Luck!
