07-28-2004, 04:49 AM   #1 (permalink)
giddyup1
help /advice
Here are the specs of a solid roller cam that was suggested by crow cams here in aus.
321/329 adv
262/264 @.050
612/617 lift
111 lobes
.018 hot lash
3500-7000rpm
what do you guys think? Does the above rpm range sound right? Its to go in my 347.
giddyup1 is offline   Reply With Quote
07-28-2004, 06:08 AM   #2 (permalink)
FoMoCo
help /advice
Ya rpm level sounds about right - don't know what the rest of your combo is but that is a healthy cam so you better have the heads that flow some good numbers and decent compression or that thing will fall on it's face.
07-28-2004, 07:28 AM   #3 (permalink)
giddyup1
help /advice
Below is what I told them............is it up to speed with their suggestion?
68 mustang, tremmec 3550, 4.1 diff, 235/60/14 tyres,
> 347, 10.2 comp, ported alloy windsor snr heads, Quad webers 44mm idf
> current cam ,comp cams 294s(560lift, 248@.050, 110 lobes, single
pattern,
> solid flat tappet) installed dot to dot.
> 1 3/4 4 into 1 headers 40 inches long, dual 2.5 pipes.
> The quad webers are off the engine replaced by Trickflow R, upper and
> lower efi manifold, 75mm throttle body
> 32lb injectors,haltec e6x ecu.
> The intake runners are 212cc, exhaust unknown.
> intake exhaust
> 67.2@100 57.8@100
> 139.4@200 117.2@200
> 197.9@300 151.9@300
> 243.4@400 185.6@400
> 275.1@500 193.7@500
> 298.1@600 203.2@600
> 309.2@700 209.3@700
07-28-2004, 08:39 AM   #4 (permalink)
tonys10sec306
help /advice
Get your self a custom cam that would be the way to go.I would give cam research a buzz.I have used a few of cam research cams in the past.i am very happy with the cams they grinded for me. http://www.camresearchcorp.com
80 cobra high 10's long rod 306 all motor. iron heads,flat tappet cam, mufflers and d.o.t tires.3100 pounds
84 mercury capri 308
97 merecury mountaineer 5.0
<font size=-1>[ This Message was edited by: tonys10sec306 on 7/28/04 8:40pm ]</font>
