08-08-2004, 05:03 PM   #1 (permalink)
htwheelz67
wheel spacers
After finally getting my 17x9.5's and 275 40 17's on the rear of my 67 vert, with the versailles rear its a bit too close to the inner wheelwells, are spacers wise to use? I am talking like 1" billet type spacers with there own studs. My only other option would be a different offset or custom offset wheel........
htwheelz67 is offline   Reply With Quote
08-08-2004, 06:38 PM   #2 (permalink)
Luv70sFords
wheel spacers
I never had a problem with them, ran em on my mustang, and then an offroad ranger when I moved wheels around. Work great.
08-08-2004, 09:06 PM   #3 (permalink)
tonys10sec306
wheel spacers
Spacers will work fine
tonys10sec306 is online now   Reply With Quote
08-08-2004, 09:19 PM   #4 (permalink)
MonsterMach
wheel spacers
I have a pair on the front of the 55 F100 Project (with the 78 Trans Am front end subframe. I needed them to match the width up front better with the Lincoln rear end and to match the bolt pattern up front to the rear.
I found a pair that gave me an extra inch on width and took me from five on 4.75" to five on 5" bolt pattern. So far it's working out fine but it's not a tried and road proven combination yet.
08-09-2004, 11:04 AM   #5 (permalink)
Nastystang
wheel spacers
Should be fine.
One thing though, you are not supposed to run wheel spacers at the drag strip. Dont know if that is something you do with your car, but wanted to throw that out there.
08-10-2004, 04:22 PM   #6 (permalink)
kleetuz
wheel spacers
Just to let you know. I recently put some 1" wheel spacers on my '70. I found them on ebay for $150 for a set of four, and they are very nice billet aluminum spacers. The only problem is that they come with pressed in metric 12mm studs so I had to buy some more lug nuts, not a big deal just more $.
kleetuz is offline   Reply With Quote
