351W Future Engine Modifications - Request Expert Opinions
I have a 70 mustang 351W Ram Air Mach 1. its primarily used as a sunday driver. Its never been to the dragstrip. I want to increase the motor performance in a two phases due to marrage expenses next august. This is what I am thinking. Phase 1 (2004); intake, heads and roller rockers. Phase 2 (2005) 393 or 408 stoker, roller cam. I want to plan this out, and your expert opiions are requested and appreciated. A few questions to start this off. Will AFR 185's fit with my current engine setup? Will AFR185's be a good selection for street use when I stroke the motor? What roller cam would you recommend? What cubic inch stoker kit would you recommed for my application? All recommendations are appreciated. Let it rip!
My motor specs are: bored .030 over, stock rotating assembly, crane fireball cam, I think .469 / .494 lift, 214 / 224 duration, offenhauser dual plan manifold, holly 600 cfm, roller timing chain, fluiddamper balancer, milioden 8 qt pan, windage tray, MSD 6al, stock dist with crane adjustable vacumn advance and electronic pick up. Hooker 1 5/8 jet hot super comp headers, 2.5" dual exhaust with folwmaster delta mufflers. The car has a 9 " 3.50 traction lok rear end. TCI torque converter 2400-2800 stall speed, well built performance FMX tranny.
