08-20-2004, 01:47 AM   #1 (permalink)
gtnrb71
Mustang II front end clicking? need help
I just finished installing mustang II on my 71 torino and wow what a difference. It handles so much better however the front end clicks when I hit a bump. I checked all nuts and bolts and everything is tight. It almost sounds like the springs. I installed 2" drop spindles on it and now clicks when I go over a bump. It sounds as though the springs aren't tight and when I hit a bump they move and click. Has anyone else had this problem? any help is greatly appreciated
gtnrb71 is offline   Reply With Quote
08-20-2004, 09:02 AM   #2 (permalink)
coolfalcon
Did you use the rubber pad in the roof were the spring nests? Mine dont make any noise that i can hear.
08-20-2004, 07:23 PM   #3 (permalink)
gtnrb71
yeah the rubber pads are in there and every nut I can find it tight yet it stick makes noise.
08-20-2004, 07:30 PM   #4 (permalink)
HankyJ
Mine doesn't click. How old are the front shocks? Eventually they go bad and they start clicking.
08-20-2004, 08:35 PM   #5 (permalink)
gtnrb71
everything is brand new, it only has a few hundred miles on it. I thought maybe it was the sway bar but I went under and tightened every nut, bolt and shook everything I could and I think it is coming from the springs but I don;t know what it is. It was at first coming from just the pass side but now it is both sides. any other ideas? It drives fine no wobles that would make me think a control arm was loose everything handles tight just a cluncking noise? Thanks
08-22-2004, 03:46 PM   #6 (permalink)
thekingofazle
did you grease your balljoints?
