How to rotate radial tires?
I know the old radial tires would self destruct if you swapped sides when rotating the tires. Something about being turned one way for a while and then the other separated the tread from the tire...The "correct" way for most new tires is fronts to backs, then backs to opposite corner fronts. My dad still holds to the old method, he won't swap sides just because it seems like it would be bad for the tire.
On the new radials it isn't supposed to matter, but better safe that sorry.
<font size=-1>[ This Message was edited by: thekingofazle on 8/27/04 9:23am ]</font>
