08-30-2004, 08:17 PM   #1 (permalink)
crhumper
edelbrock fuel pump and fuel line size
my stock fuel pump finally went out the other day, so i'll be upgrading to a high flow pump...i'm thinking about the edelbrock street pump for my 289...any experience with these? also, will my 5/16" fuel line be adequate for now or should i upgrade to 3/8"...approx. 300hp 289. thanks
crhumper is offline   Reply With Quote
08-31-2004, 10:25 AM   #2 (permalink)
ckelly
Well - our's leaked oil after 5 months. Edelbrock tech sent me the repair parts - not a big deal. Pump worked for about 4 weeks more then quit. It's in a box on the bench, haven't torn into it to see why - been too busy. Not a ringing recommendation. I put the old stocker back on it and we've been racing that for months now. About a 240HP 302. I'd use 3/8 line anyway - most of the performance pumps use that size fitting. Depending on the car, your feed from the tank may only be 5/16".
08-31-2004, 07:25 PM   #3 (permalink)
crhumper
i believe the sending unit is 5/16"...should i change that? if so, what is the best way to do this? just bend up a 3/8 line and solder it to the sending unit or weld one?? thanks
08-31-2004, 08:31 PM   #4 (permalink)
FoMoCo
If you can't find a sending unit with a 3/8 outlet solding one in is all you can do.I don't recommend putting a 3/8 on without changing the pickup.
08-31-2004, 09:28 PM   #5 (permalink)
tonys10sec306
i would use 3/8 front to back
