D0VE-A ?
Olli,
The D0VE block is a desireable piece as it has the thick main webbing of the four bolt main blocks but machined for two bolt mains. These blocks have very good cylinder wall thickness and can easily be converted to the splayed bolt main cap configuration. Modified thusly these blocks can handle 800HP reliably. Getting this motor for a low price would be a wise aquisition as it should also have the early small chamber heads. For more info on the potential of these engines, check out 460Ford.com.
Aufwiedersehn,
Ric
