11-08-2004, 12:34 PM   #1 (permalink)
jazjoh
3.73 Gears with a 1988 GT AOD \"Help\"
I just had my transmission re-built and at the same time I also changed my gears from the 2.73 factory to 3.73.
I was expecting some changes but I'm not sure if the rpm are right.
At 65 mph with the card in drive my rpm's are around 4200 which seems way to high at only 65 to me that means I can't drive the car in drive anymore.
With the car in O/D at 65 mph the car is around 3200 rpm.
in drive I feel 2 shift and that seems right
in O/D I feel 3 shifts and that feels right
but it just seems like in drive the car is in second gear...
Wanted to know what other folks are getting with modified gear changes on a AOD
Also my tire size 235 45 17.....
jazjoh is offline   Reply With Quote
11-08-2004, 12:46 PM   #2 (permalink)
cahorne
I have 3.89 and a 5 speed (.6[img]/phpBB/images/smiles/icon_cool.gif[/img] and turn 2300 RPM at 70 MPH. What gear ratio is your overdrive. yours sounds a little high
cahorne is offline   Reply With Quote
11-08-2004, 01:00 PM   #3 (permalink)
1 Bad 88 GT
Did you change the driven gear to correct the speedo? If so what gear did you use(color)?
BTW 3200 at 65mph is about right due to your slightly smaller tire.
11-08-2004, 01:04 PM   #4 (permalink)
jazjoh
in overdrive it should be 1.00
11-08-2004, 01:05 PM   #5 (permalink)
1 Bad 88 GT
No it's not. OD is .68:1. Drive is 1:1.
11-08-2004, 01:06 PM   #6 (permalink)
1 Bad 88 GT
Anyway I asked what driven gear you used in the trans when you did the gear swap.
11-08-2004, 01:15 PM   #7 (permalink)
jazjoh
you are right it is 68 in O/D &amp; 1 in drive
21 Tooth
11-08-2004, 01:24 PM   #8 (permalink)
1 Bad 88 GT
Since you did swap the driven gear then the speedo is pretty close(tire size is off a bit). I don't see a problem.
11-08-2004, 02:07 PM   #9 (permalink)
jazjoh
just does not seem right that I can stay in drive up until maybe 70 - 75 before I'm at 5,000 rpm maybe that's right and I just have to move to O/D
11-08-2004, 04:48 PM   #10 (permalink)
ckelly
You should ne running near 3500RPM at 70 MPH with that tire diameter in 1:1, 2350 or so in .67 OD. Make sure your tach and/or speedo is working correctly. 5000 RPM in 1:1 would put you right at 100MPH.
