building a 428FE for my 1968 mustang
11's?... a street car, thats non-computer controlled; That's a tall order. Not impossible, but not as easy as you might think.
Today's, Old-tech engines are power houses compared to the originals. Better tires, better cams, carbs, heads..etc, make it a lot easier to build a street runner that would embarss the bracket cars of just a few years ago. But 11's are not just about horsepower, to run those numbers you will need the whole package. Transmission, gears, traction, suspension, heads, header (full length, 4-in-1)...maybe some weight reduction.
Yes a 428 will fit, it won't be easy to work on, but it will fit. You may want to look into triming the shock towers, sooner rather than later, to make it easier to fit and work on. Check the tech articles, on the home page...there is a build-up on a 1969 that details pretty much what you will need to do to run the numbers.
Be ready to open your wallet and cry in your beer a few times before it all comes to together. You can expect 13's - 12s without too much headache, then you need to get serious
